"Communication Error With Gateway" (WIFI Hub)
Gavona
Chat Champion
Several times over the last few months we have lost connection to the internet.  The light on the WiFi Hub remains white.  The only solution seems to be to re-start the router (leaving it off for 30 mins).
When the problem presents, we can reach the login page of the router but on entering the password we get an error "Communication error with gateway" and the password clears. (so login fails).
Windows 10 troubleshooter tells us: "The connection between your access point, router or cable modem and the Internet is broken ... More Details: The network gateway is accessible, but Windows couldn't receive network traffic from the Internet. "
I am using TalkTalk Wi-Fi Hub version SG4K10002600t
Restarting the modem has so far completely resolved those issues.  However the logfile is particularly unhelpful as it does not appear to log everything and many entries are dated 2013.  Even with the most detailed reporting specified (Debug) the most recently dated entry is 1 November! (I keep the router on 24/7) I think I recall seeing this issue reported in another thread so it is probably not in itself indicating a problem with the router more with the software relating to the log file.
So, (i) why am I losing connection - can anything be done to solve it.
(ii) Why am I unable to login to the router - does this actually suggest a problem with the router is at the heart of the issues?
Thanks in advance,
G
Thanks,
Gavona
Hi @Gavona
There are bugs associated with the system log currently. I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
OCE_Debbie
Hi Gavona
Apologies for the delay.
I've completed a line test which hasn't detected any faults and the connection appears to be stable.
I can send a replacement router for testing, would you like me to arrange this?
