router
3 REPLIES 3
Hi do I need to plug my new talk talk router into the bt openreach modem which my plusnet router is plugged into. It only shows it going into phone socket with or without filter but would it be better if into openreach modem. thanks
I'm assuming you are on fibre, and if so you should be able to plug this in directly without the need for the Openreach one.
Thank you . Im still using my plusnet router but the switch was today! I assume that talk talk fibre is running through my old set up at mo. Cheers for advice on the 1st question
Hi aintnecessarilyso,
Welcome to the Community and please let us know if you need any assistance 🙂
