slow broadband
3 REPLIES 3
I recently upgraded my Broadband service from Fibre35 to Fibre65 with a ‘go live’ date of 17/11/20. Ever since then download speed has been 25-26 Mbps, consistently over two days, which is well below expected mid-60s! It is even below the guaranteed minimum of 40 Mbps. I have tested speed over days with the router connected at end of phone extension and at master socket. Thus, there is no drop in speed due to house wiring. What can TT do about this to give me the service I am now paying for? Is the fact that I am still on an FTTC set up? If no improvement I shall investigate and consider moving to another ISP.
SPEED TESTS OF FIBRE65
Results from master socket
Date
Latency
Download
Upload
ConnType
ServerName
Nov/20/2020 11:03
17.987
25.92181
7.04197
Wifi
Gloucester
Nov/20/2020 7:41
18.985
25.48651
7.13275
Wifi
Gloucester
Nov/19/2020 22:01
18.985
25.92506
7.08569
Wifi
Gloucester
Nov/19/2020 19:42
18.99
19.58025
7.11237
Wifi
Gloucester
Nov/19/2020 16:53
16.987
25.35014
7.21567
Wifi
Leicester
Nov/19/2020 15:35
18.985
25.7482
6.86088
Wifi
Oxford
Nov/19/2020 15:33
22.737
25.85702
7.10992
Wifi
Telford
Nov/19/2020 13:38
22.977
25.89754
6.94557
Wifi
Telford
Nov/19/2020 12:41
22.981
25.74276
7.14543
Wifi
Telford
Results from extension
Date
Latency
Download
Upload
ConnType
ServerName
Nov/19/2020 10:40
16.996
2.303448
6.71236
Wifi
Leicester
Nov/19/2020 10:39
16.99
25.83318
6.43874
Wifi
Leicester
Nov/18/2020 15:44
22.983
14.97015
17.9585
Wifi
Telford
Nov/18/2020 15:37
22.974
19.82949
21.0739
Wifi
Telford
Nov/18/2020 15:37
20.988
14.25365
18.9086
Wifi
Keele
Nov/18/2020 15:36
19.988
17.93886
18.8497
Wifi
Keele
Nov/18/2020 8:27
18.608
22.82769
7.91708
Wifi
Leicester
Nov/18/2020 7:56
23.985
24.1151
7.6965
Wifi
Telford
Nov/18/2020 7:55
17.988
22.52851
8.0439
Wifi
Leicester
Nov/17/2020 21:05
17.987
19.5552
9.4559
Wifi
Leicester
Jul/29/2020 11:51
19.976
0.443176
9.88329
Wifi
Liverpool
Jul/29/2020 11:30
11.992
0.386664
11.486
Wifi
Manchester
Jun/21/2019 17:03
19.986
35.7141
16.8681
Wifi
Telford
Jun/21/2019 17:02
13.989
33.30877
16.5306
Wifi
Coventry
Jun/21/2019 17:01
14.989
34.33753
17.1599
Wifi
Coventry
mbow
Hi @mikebow,
Are you able to do the speed test 'wired', as if you do them wireless then results could be affected by many other things.
If you log into 'My Account' can you see that the speed boost is active against your broadband package.
If you go to the Service Centre what does it show for your 'estimated speed' and 'measured speed'. If your 'measured speed' is showing something closer to the higher speeds you would expect then it would be a good idea to switch the router off for over 30 minutes, then when you switch it back on it will start a new 'session' in the street cabinet, this can sometimes help it pick up those faster speeds.
Some of your results imply that the boost is active, as it shows you are getting upload speeds of well over 10, however some of the readings are over 20, and Fibre 65 has a maximum upload speed of 20mbps, so those readings might not be super accurate !
 Hi Sky_TV
Thanks for info. Just measured speed several times on my desktop with ethernet connection; got 26down and 6 up. Checked My Account and shows Fibre65 is active.Service centre estimates speed to router as 45-78, measured 36!  I also ran Network Stability test; this came up with a fault on line and to book Openreach engineer. This I have done for Tuesday, 24th. Will keep you posted of outcome.
Regards Mikebow
mbow
Hi mikebow
I'm sorry for the delay.
How are you getting on following the engineer visit?
