good morning , for the last days /weeks my speed has been dropping and now seems to have settled at less than half what it was and should be .
my router shows 80/20 but i am getting 35/15 can someone look into this for me as nothing has changed with my setup .
thanks SG
Solved! Jump to the Best Answer.
Morning SG,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault and the sync speed looks good. Is this a wired or wireless speed test? Is their any improvement in throughput speed if you switch the router off for a full 30 minutes and then retest this again as this will reset the current session.
i checked the wired connection and that is giving 75/18 ! so i then realised i had switched on a wifi extender , so i turned it off and all is back to normal .
sorry i wasted your time but thanks anyway 🙄
Hi skygrowler,
Not at all, we're happy to help and I'm glad to hear that you've managed to get to the bottom of this 🙂
