slow sync speed issue
28 REPLIES 28
is there anyone who can help with my slow sync speed of 8mbit, i normally get around 33mbit?
can dlm be reset?
Thanks you. My profile is already setup.
Here is a link with the issue it has been happening for a long time and still nothing has been done!
https://community.talktalk.co.uk/t5/Product-Archive/Frequent-disconnect-and-slow-speed/m-p/2128205#M...
Hi Don,
I'm sorry to hear this. I've run a test on the line which has detected a potential fault. Are you experiencing any issues with the voice service such as noise on the line or no dial tone? Does your master socket also have a test socket?
There is no issue with voice calls from the landline. My router is connected directly to the dual outlet openreach MK3 master socket. I have no other wiring within the house apart from that outlet
Hi Don,
Thanks for confirming this. I've passed the low speed over to our Network Team for further investigation and I'll let you know as soon as I know more.
Hi Don,
I've received an update to advise that the fault has been passed to Openreach for further investigation.
the speed has now increased but im still getting disconnects every day and already seeing a decrease in sync speed again??
Hi Dongreening86
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
Is the router connected at the test socket? I can then pass this over to our Network Team for investigation.
As previously stated My router is connected directly to the dual outlet openreach MK3 master socket. I have no other wiring within the house apart from that outlet.
if you could get this investigated that would be great thanks
Hi Dongreening86,
DLM changed your profile on the 27th, sync speed is now 40Mbps. How have the disconnections been since your last post?
Hi thanks for that. The disconnects have been at least once a day since my last post. All the engineers that have been to the property and the surrounding properties have all said the same in that the equipment at the local exchange cannot sustain the amount of connections it currently has. I'm not sure whether this is something you can relay back your end?
There are no reconnections showing since the profile change this morning so can you bump the thread tomorrow and we'll see if there have been any further disconnections
Regarding what the engineer told you, this is something that they should have relayed back as they complete a fault report based on their findings
Just to update I had 3 disconnects that I know of yesterday 16:19, 18:05 and 18:41. Sync speed is still at 40mbps at the moment.
Hi Don,
I've asked our Network Team to take a look at the intermittent connection now. If you don't hear back by the end of today then please can you bump your thread and we can re-check this again for you.
Hi Don,
Our Network Team have looked at this and advised that they think this may be related to the router. Just to confirm, have you ever tested with a HG633?
I believe the hg633 is what I using and has been replaced once before a while ago but if you think it may be this I'm happy for you to send a new one to try?
Hi Don,
I've ordered the router, it should be with you within a couple of days but please allow up to 5 working days for deliver
