hi i notice my superhub now changes the channels
i take 2.4 off auto to 6 but goes back to any channel it likes
5ghz i like as 36 but wants to go to 44
how can i stop this i tried every broswer going no luck
Hi jasonvoor1313
Are you using the Wifi Hub?
It's our Wi-Fi optimisation technology that is picking the best channel in use.
yes your superhub
it still wont keep off auto
so i turned off the wifi on both bands on hub
and using asus rt 56u for wifi connected to the superhub
as there been a new update for the hub
as last time i had to factory reset the hub
as a factory reset didnt solve nothing this time
Hi jasonvoor1313,
Your router is running the latest firmware version although there is new firmware due for release soon
