upgrade
Hello.
My package at the moment is faster Fibre  (36 pounds) and fibre speed boost(5 pounds) =(total 41 pounds)
i would like to use the upgrade options and reduce my bills.
The only options  is 23.50 pounds/month for Fibre fast.
Will i get fibre speed boost with it as well?
Also i am using router Huawei HG633 and have a deal options to upgrade it for Wi-fi hub for 30 pounds.
I don't understand when i will renew my contract, will Talk-Talk send me a wi-fi hub or standard router hg 633?
because i would like to try a new wifi hub.
Regards.
Mariowski
Insightful One
You won't get the speed boost unless you explicitly ask for it.  If you do ask for it you will have to pay for it at the current monthly rate, or whatever you can negotiate.
As for the router as you are renewing your contract, rather than being a new customer, I would not expect them to send you one unless you request the upgrade to the Wi-Fi Hub they have offered you.  In which it will cost you a one-off payment of £30.
Thanks for your help.
