very poor wifi on hg633 super router
3 REPLIES 3
brianthesnail123
Hi guys
           i have changed my 2 pc,s to wireless and have noticed a significant reduction in speed ....normal speed should be 73mbps down and 9mbps up .......however my results are much different
i expect some performance drop on wifi but this is over half .... granted 29mbps is still usable but not when you paying for 70mbps .....
        i hope you can help
note : i have done all the normal diagnostics such as leaving the hg633 off for 30min and even overnight but no change
             hope you can help
                    thanks
brian smy
Hi brianthesnail123
The sync speed looks good (78mb)
Have you tested different wireless channels to see how the connection compares?
brianthesnail123
Hi debbie
             changed channel ... initially it was ok but dropped again .......stilll usable but well below the fibre speeds expected
brian smy
Hi brianthesnail123
Do you have any devices connected wired? Are these devices experiencing the same issue?
