when does my router get upgraded?
1 REPLY 1
weealdorfc13
Hi, I currently have the super router but recently upgraded to the fibre one and i'm wondering what happens next. do I receive a new router in the post? how long do I need to wait?
Thanks - Alan
fre55die
By "recently" when exactly do you mean ??
The new router was available free for a time which expires shortly. It is available via the LOYALTY team for £30 BUT IFYOU UPDATED DURING THE PROMOTION PERIOD IT SHOULD BE FREE !!!
