I run win 10 on my laptop,everything has been fine for the last few months,speed,connections etc.now every time a bus(first bus) passes by(road is about 100yds away)I get notifcation flash up saying tap to connect with first wifi.this closes my broadband connection and I have to reset and reconnect.Same thing happened about 9 months ago but stopped after a few weeks.have I been pressing a wrong button or what?
Hi jontov
Have you tested different wireless channels? Change your wireless channel
Which router are you using? (make and model)
