wifi hub
skygrowler
Insightful One
again , not as far as i know because the only wired connection is an iMac that is not used very often.
skygrowler
Insightful One
it seems to be a fault with the 2.4 channel because all of the wifi hubs have had a problem keeping my cctv online and they are all 2.4.
Hi skygrowler
I've contacted our Products Team in regards to this and I will post back on this thread as soon as I receive further information.
skygrowler
Insightful One
OK thanks
Hi skygrowler
Which firmware version is currently showing on your router?
skygrowler
Insightful One
version SG4K10002600t
Hi skygrowler
Our Products Team have asked us to try firmware version 1400t again. Please can you factory reset the router and I can then update the firmware?
skygrowler
Insightful One
Did it  nothing happened
skygrowler
Insightful One
@OCE_Debbie what happened ?
Hi skygrowler
Apologies for the delay.
I've now changed the firmware. Please can you retest and let us know how you get on?
skygrowler
Insightful One
i certainly will ,LOL
skygrowler
Insightful One
I don't know if this is any help but my Cctv works better when I am away from home on mobile data. On WiFi they more often than not take ages to connect or just time out .
Hi skygrowler
Is this still the same following the firmware update?
skygrowler
Insightful One
Yes it is
Hi skygrowler
Are you able to connect them (CCTV) to the 5ghz channel?
skygrowler
Insightful One
No .
Hi skygrowler
Do any other devices using 2.4ghz channel also experience the same issue?
skygrowler
Insightful One
yes i have one laptop that is 2.4 and i think that suffers the same problem.
Hi skygrowler
Have you tested this (laptop) recently since the firmware update? I'm just trying to determine if this is just affecting the CCTV or all devices using 2.4GHZ.
