2.4 ghz WiFi dropping
Hulkster81
Message 10 of 10
Hi , I hope someone can help me with this ongoing issue . In the last couple of weeks my WiFi 2.4ghz keeps dropping and sometimes disappearing altogether . We often get the messages saying can't connect or not connected to internet yet 5ghz works fine . Unfortunately we have some devices that don't use 5.0 and this is happening more frequently . I have tried changing WiFi channels and reset the WiFi hub but to no avail. As I write this I am watching Netflix on 5.0 GHz with no issue but devices can't even find 2.4
Please help my kids are driving me nuts
9 REPLIES 9
Message 1 of 10
Hi @jrfansurti
Please can you create a new thread on the Community, we can then look into this further.
Message 2 of 10
Hi I am experiencing the exact same issue, TV and computer on 2.4ghz are dropping off every 20 mins or so and mobile phones are working fine.
Can you help me too please?
Message 3 of 10
Message 4 of 10
Will do . Thanks for your help
Message 5 of 10
Hi Martin
Debbie 🙂
Message 6 of 10
No , I am using the WiFi hub . I purchased from you a few months ago
Message 7 of 10
Hi Martin
Are you currently using the HG633 router?
Message 8 of 10
That would be great . Will it be the same as the WiFi hub I'm currently using ?
Martin
Message 9 of 10
Hi Hulkster81
I can send a replacement router for testing, would you like me to arrange this?
