35mb
Safc10boxer12
Chat Champion
Message 15 of 15
I'm only get 35mb but it my line is satins it can do 65mb or something like that... How do I achieve this ?
14 REPLIES 14
Message 1 of 15
Ok thanks
Message 2 of 15
Hi  Safc10boxer12
I've checked the connection stats again and the sync speed is still at 43.1mb.
I have also checked the predicted speed range and your current speed is within the range for your line.
Message 3 of 15
Will do
Message 4 of 15
Hi Safc10boxer12
Would it be possible to leave the router at the test socket for a while longer to see if DLM makes any further changes?
I can then check the connection stats again tomorrow to see if the speed has increased any further.
Message 5 of 15
Yes it's still in the test socket
Message 6 of 15
Hi Safc10boxer12
I've checked the connection stats and the sync speed has started to increase from 42.9 to 43.1mb.
Is the router still at the test socket?
Message 7 of 15
Bump
Message 8 of 15
Hi Safc10boxer12,
Thanks for the update. Please can you bump your thread on Monday and we can re-check the connection stats again to see how the sync speed compares 🙂
Message 9 of 15
It's in the test socket now 👍🏻
Message 10 of 15
Hi Safc10boxer12,
Yes you would still be able to use the internet if the router is connected at the test socket. Is the router currently connected at the master socket or an extension socket?
Message 11 of 15
yeah
But can I still use the internet too ?
Message 12 of 15
Hi Safc10boxer12,
Thanks for confirming. Would it be possible to test the router at the test socket for at least 48hrs to see if DLM increases the sync speed?
Message 13 of 15
Morning
Yeah it does
Message 14 of 15
Hi Safc10boxer12,
I've run a test on the line which hasn't detected a fault. Just to confirm, does your master socket have a test socket?
