4 Weeks an getting worse
1nvisiblade
Message 18 of 18
So 4 weeks ago I contacted TT about the speed of my broadband.
It's been dropping every week since.
Online chat doesn't help one bit, an just keep going around in circles.
Like have you moved your router etc etc.
Everytime I tell them my router hasn't moved in the 2 years I've been with Talktalk.
Started off with great speeds (for my area) 50mb+
Since I recently resigned to TT, my speeds are now less than 35mb over 2 last weeks.
An today my speed is actually worse than dial up.
My router is on 24hours a day (chat keep asking if i turn it off?)
Todays speed via the router dashboard 5.7mb Down / 5.1mb Up
It's getting beyond a joke.
Tj
17 REPLIES 17
Message 1 of 18
Hi 1nvisiblade
No problem. Please let us know how you get on following this visit.
Message 2 of 18
Thank you for your help.
Tj
Tj
Message 3 of 18
Hi 1nvisiblade
The engineer visit has been arranged for 23/10 PM (1pm - 6pm)
Message 4 of 18
Hi.
Pm is generally better for me.
an ok about the charges
Tj
Message 5 of 18
Hi 1nvisiblade
Thanks for confirming your details. Please can you also confirm possible engineer charges and provide your availability for this visit AM and PM?
Message 6 of 18
Hi 1nvisiblade
I'm just sending you a Private Message to confirm some details so we can arrange an engineer visit.
Message 7 of 18
That would be great thank you
Tj
Message 8 of 18
OK, we can arrange an engineer visit to take a look at this for you. If you'd like us to do this please let us know and we'll confirm some details with you
Message 9 of 18
I don't have a house phone to test with, haven't had one since I moved in here lol.
My router is plugged into the socket with the faceplate removed with a filter (as instructed by online chat.) I'm not sure if the socket does have a test socket it's the mk4 5c socket.
It has improved slightly an my connection is as follows, but still not getting anywhere near my old speeds. The best I've got is pictured below.
I have noticed it is also restarting / resetting itself during the day / night.
Tj
Tj
Message 10 of 18
Hi 1nvisiblade,
Thanks for trying that. Are you experiencing any problems with your telephone service, any noise on the line?
Is your router currently connected to your test socket if you have one?
Message 11 of 18
Left off while I went out for an hour.
Connection is just as bad.
An just done your network status through my account an got the same as i got this morning.
Tj
Message 12 of 18
Message 13 of 18
Sure.
Will do it in the next 15 mins.
An let you know.
Tj
Message 14 of 18
Thanks for updating, Line test is clear and your line profile isn't restricting your speed to 10Mbps so could you switch your router off and leave it off for at least 30 minutes then switch back on and test. Please let us know how you get on
Message 15 of 18
Hi Chris,
I have just updated my profile.
So the last couple of days my speed will not go above 10mb.
I did have 16mb at one point but my connection decided to die an reset itself.
I have left my router off over night while so it would have a decent reset, slightly longer than the 20 min needed.
Turned it back on when I woke to get 10mb again.
The above is about the best i'm going to get.
An below is the worst I've got a couple of days ago.
regards
Tj
Tj
Chris-TalkTalk
Message 16 of 18
Hi 1nvisiblade,
Welcome to the Community
If you still need assistance can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 17 of 18
Hi @1nvisiblade ,
You may well have done these checks (or the online chat people may have), but just in case you haven't...
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
Then they will hopefully be able to respond to this post within a day or two.
