5ghz WiFi problems with Huawei router
Supermansam
Message 16 of 16
I have recently joined TalkTalk from BT. The BT Smart hub was faultless and I could connect to the separated 2.4ghz and 5ghz bands at will the full coverage of my home, including a smartplug in the garage.
I now have a TalkTalk Huawei DG8041W router in the same location. The bands have been separated and I have used WifiAnalyzer to find the least congested channels. 2.4ghz seems fine, but doesn't reach the smart plug in the garage which my previous BT router could. My Win 10 desktop upstairs connects to 5ghz, but with less signal strength than the BT router. All closer devices connect fine on either band, except for my two gaming laptops.
The laptops are both Win 10 and from different manufacturers. They both use up to date Intel drivers from Intel's website. They both worked faultlessly on 5ghz with the BT router. However, they will not connect to the 5ghz of the TalkTalk router no matter what I do. I have tried changing the channels (band A 36-48 and also tried above) and I have tried changing the channel width from Auto 20/ 40/ 80 all the way down to 20 and in between. I have tried reboots, reinstalling drivers etc but no success. The laptops just won't connect to the 5ghz band. They connect fine on 2.4ghz, but being gaming laptops, I need the speed of the 5ghz band. There are no sources of interference in between (same room, no cordless phones, mirrors, walls etc) and as I stated, they worked perfectly with my old router (and still do when I tried again with the old router - but obviously with no internet).
Can anyone advise how to get the laptops to connect to this router? Do I have a faulty one? Is there a different model that works better on 5ghz?
Many thanks in advance for your time and advice.
15 REPLIES 15
Message 1 of 16
Hi Supermansam
I'm really sorry for the delay.
The WIFI optimisation has now been switched off, please let us know how the connection compares.
Message 2 of 16
Hi Karl,
Thanks for sending out a Sagemcom router. I split the SSID to 2.4ghz and 5ghz and can confirm that the laptops connected instantly to the 5ghz band.
The only issue I have now is that when I change the channels to the best ones for my setup, the channels change back to ones determined by the router sometime later (overnight?). I read that there is something you control on my account that overrides this (line optimisation?).
Could you turn this off for me so that I can take control of the channels? Many thanks.
One other thing, I did not receive a returns envelope for the faulty router.
Message 3 of 16
a router is on the way and a returns bag for the other router.
Message 4 of 16
They will get to you.  Save your money and wait.
Don't repost on your thread until an OCE get back to you. Otherwise it will move lower on the queue.
Cheers
Message 5 of 16
Hi Keith,
Did you get a chance to ask TalkTalk to replace my router?
Is it just a case of waiting until someone gets around to seeing this thread?
I'm thinking about buying a new router if it will be a long wait.
Many thanks for your time.
Supermansam
Message 6 of 16
Hopefully won't be too long before an OCE has a look at this... Hoping to get this resolved on the weekend if possible 🤞
Message 7 of 16
Hi.
Looks like 5ghz is faulty
Will let the OCE's decide on course of action on Monday onwards.
Message 8 of 16
Thanks for your input, Paul.
Both the 2.4 and 5ghz bands are set at full speed.
Auth mode is set to WPA2, PreSharedKey and AES.
I have tried TKIP etc but with no success. My network adapters on the laptops support the router's settings and are both recent with up to date drivers. The settings were the same on my old BT router and on that both laptops worked fine on 5ghz.
I'm hoping that it is a problem with the router since once that is replaced it should work. If it doesn't then I'm stuck without a solution that I can think of, other than using my TalkTalk router as a modem and return to my old BT router.
Message 9 of 16
I have the DG8041 and have no issues with the 5Ghz band or it's strength
Logon to router via admin account.  pwd on rear of router.
Select the wifi settings and see if band 1 2Ghz is running at 450Mbps  and Band2  5Ghz at 1732Mbps.  If so it's ok so far.
Have a look at the WLAN menu
Have a look at Auth Mode, and it should be set to WPA2 PreSharedKey
WPA PreShared key should have same password that wifi systems use to connect with router.
You may want to try via the drop down menu under Auth mode to something other than what it is set to. Make sure the windows system is using the same Auth mode.
If it still does not connect on 5Ghz then router is the problem
Message 10 of 16
Thanks for looking over it. I'm familiar with networking to a degree but I couldn't find anything in the router settings or the network adapter settings to indicate a problem or incompatibility.
Please request a replacement router for me and I will give this is try.
Many thanks again for your input.
Message 11 of 16
Well, other than the fact you are not connected I can't see anything obvious. All I can suggest then is for me to ask TalkTalk if they will consider swapping your router out.
Message 12 of 16
Here are the details you requested:
netsh wlan show drivers
Interface name: WiFi
Driver : Intel(R) Wireless-AC 9560 160MHz
Vendor : Intel Corporation
Provider : Intel
Date : 30/11/2020
Version : 22.20.0.6
INF file : oem333.inf
Type : Native Wi-Fi Driver
Radio types supported : 802.11b 802.11g 802.11n 802.11a 802.11ac
FIPS 140-2 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : No
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Open Vendor defined
WPA3-Personal CCMP
Vendor defined Vendor defined
WPA3-Enterprise GCMP-256
OWE CCMP
IHV service present : Yes
IHV adapter OUI : [00 00 00], type: [00]
IHV extensibility DLL path: C:\WINDOWS\system32\IntelIHVRouter08.dll
IHV UI extensibility ClSID: {00000000-0000-0000-0000-000000000000}
IHV diagnostics CLSID : {00000000-0000-0000-0000-000000000000}
Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
netsh wlan show interface
There is 1 interface on the system:
Description : Intel(R) Wireless-AC 9560 160MHz
GUID : ee7e69b3-2a71-434e-9414-5fdae6b28dfd
Physical address : 98:af:65:3a:0e:67
State : disconnected
Radio status : Hardware On
Software On
Hosted network status : Not available
netsh wlan show networks mode=ssid
Interface name : WiFi
There are 12 networks currently visible.
SSID 1 : healyboy
Network type : Infrastructure
Authentication : WPA2-Personal
Encryption : CCMP
SSID 2 : SKYZN4GX_Ext
Encryption : CCMP
SSID 3 :
Encryption : CCMP
SSID 4 : SKY05B59
Encryption : CCMP
SSID 5 : Speaker.o
Authentication : Open
Encryption : None
SSID 6 : SKY0A497
Encryption : CCMP
SSID 7 : EE-Hub-oD9M
Encryption : CCMP
SSID 8 : PLUSNET-GP2S
Encryption : CCMP
SSID 9 : BTWi-fi
Encryption : None
SSID 10 : BT-3GAHWQ
Encryption : CCMP
SSID 11 : TALKTALK9BBDDC24G
Encryption : CCMP
SSID 12 : TALKTALK9BBDDC5G
Encryption : CCMP
I'm the last 2 SSIDs.
Many thanks again for you time and input.
Message 13 of 16
Yes, you may not have PMs enabled if you are new.
If they are close to the problem areas, then the cause is not the router's WiFi.
Please open a command prompt window (assuming a Windows OS) by going to:-
Start > Accessories > Command Prompt
In Windows 10, click the Window Icon & type in the search box:-
cmd
in the search box next to it. This should find the "Command Prompt" from there.
Please enter these commands one at a time, pressing enter after each one and wait for the response. Then copy and paste the output from each into your reply.
netsh wlan show networks mode=bssid
Note I will need to know the names of your wireless networks.
Message 14 of 16
Hi.
Thanks for the reply.
I can't PM you - I don't see an option for this. Maybe because I'm new?
I have attached some pictures to this post.
Thanks for your input. The laptops have a Qualcomm Atheros chip in one and an Intel AC 9560 chip in the other.
I hope there's an easy fix🤞
Message 15 of 16
Can you provide me with screenshots of all of the views from WiFi Analyser, close to the problem areas. You can PM them to me if you prefer, then I can see if I can detect a problem. Please make sure that when using the Insert Photos/Images button on the toolbar to do this, you set the size setting to large.
