on 03-05-2022 02:20 PM
My Router stopped working 7 days ago (1 day after talk talk done a firmware update on it due to it not connecting to my VPN for work).
Since then I've spent over 6hrs on the phone with an extremely incompetent customer service team apart from 1 girl (Leah) who was very helpful.
I've since been sent out an Eero box that I received this morning and it's still not connecting to the Internet?
However, there is a chance I'm not connecting it to the correct equipment?
It says to connect to the Modem? Is this the black box on the wall with the 4 lights on?
I'm losing my mind here. A week without Internet or TV (we only use Netflix and Youtube) so it's been a nightmare...
on 04-05-2022 09:44 AM
Ok thank you for confirming and please let us know how you get on.
on 04-05-2022 09:43 AM
Thank you.
I'm due a call back today at 1pm and hoping to get CityFubre engineer out to me.
on 04-05-2022 09:41 AM
Thanks for trying this. If their is also no connection directly at the ONT then it sounds like it could be the connection itself and not the router. I'd recommend live chatting our Future Fibre Team directly now so they can run some tests on the line. I've included a Help Guide below which has the link directly to the Live Chat Team at the bottom of the page.
Guide to Future Fibre and FTTP | TalkTalk
on 04-05-2022 09:32 AM
The Router model is
Sagemcom
FAST5364-3. T8
I tried connected the cable from the ONT straight in to a laptop ethernet port and I still get no Internet connection.
on 04-05-2022 09:28 AM
Can I just confirm, the make and model of the 2 routers please as we may have some settings that can be changed? Does your connection work ok if you connect directly to the ONT box?
on 04-05-2022 09:09 AM
Hi Michelle
I had already done this and have actually tried 2 Brand New Routers as well...
Thats why I was then told "I must change to an Eero box with the Fibre500..." however now I've received the Eero box and it isn't connecting to the Internet.
on 04-05-2022 06:44 AM
Can I just confirm, what is the make and model of the router that you were originally using please? Could you try factory resetting the original router then leave it powered down for a full 30 minutes and then try re-connecting this router again please.
on 03-05-2022 02:47 PM
Hi Karl
This is what I've done and still no Internet connection being found.
on 03-05-2022 02:46 PM
The black box with the lights on, will be the ONT. basically the modem for the fibre connection. You should connect the Eero to this with an ethernet cable.
