ACCESS QoS Menu?
megmog29
Message 13 of 13
Is there anyway to access the QoS menu on the DG8041W-2 Huawei Router? I am having packet loss issues and was told best way is to check my QoS on this router
Josh
12 REPLIES 12
Message 1 of 13
Closing as duplicate thread, please can you post on your original topic on the Community.   Thanks
Message 2 of 13
No worries, same to you.  🙂
megmog29
Message 3 of 13
Oh okay. Hopefully I get a response
thanks and enjoy the rest of your weekend
Josh
Message 4 of 13
They will respond right here on this thread as soon as they can after they are back online tomorrow.
megmog29
Message 5 of 13
Is there anyway to ensure the team get in touch? Every time I speak to customer services they have NO idea what they are talking about and keep thinking I am talking about my connection speed dropping which it isn’t. I feel like I need to speak to someone who actually knows what they’re talking about
Josh
Message 6 of 13
@Birchcroft Yeah, but it may help if the support team can identify an underlying problem, rather than trying to tweak it away.
@megmog29 I continue to suggest that you await a support team response, especially before spending money on kit that may not necessarily resolve the issue.
Birchcroft
Message 7 of 13
@megmog29 Using your own does have a number of advantages if you want control over your network connection.  But don't forget TalkTalk won't be able to provide support, although members of the forum might be able to depending on which router you buy.  Also if you are a fibre 35 or 65 customer you will need either a router with a built-in modem, or a separate modem.
Message 8 of 13
Or you could wait for the support team to see if they can help with your packet loss issue.
Message 9 of 13
I guess I am gonna have to just get my own router and that way I can play around with things
Josh
Message 10 of 13
I agree with @martswain
Message 11 of 13
I don't believe you can. The TalkTalk support team will advise further when they are back online from Monday.
martswain
Message 12 of 13
I don't think there is one, but @KeithFrench will probably be able to confirm my suspicions.
