AMBER WHITE FLASH- no internet
danieldonah
Message 3 of 3
Hello there. My router is flashing amber and white with no internet connection. Please help me fix this. I need to get online
Message 1 of 3
Hi daniel,
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 2 of 3
Hi @danieldonah,
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help. You may get faster support from the live chat or by phoning up during opening hours.
