AP client isolation chromecast
Reusserg
Message 2 of 2
Not able to cast to Chromecast.
Being advised to do the following :
  • Enable: Universal Plug and Play (UPnP), multicast, Internet Group Management Protocol (IGMP)
  • Disable: AP/client isolation, virtual private networks (VPNs), proxy servers, IGMP Proxy
    • VPNs and proxy servers should be disabled on your computer as well (if applicable).
AP client isolation is not an option in router settings.
Factory reset worked temporarily.
Firmware last updated 31/05/2022.
Sagemcom router CS500001.
Help please.
1 REPLY 1
Message 1 of 2
UPnP is enabled by default, to check it go to:-
Dashboard > Manage my devices > Manage Advanced Settings > Access Control > Port Forwarding
Set Enable UPnP Igd to On.
Whilst AP Client Isolation is not available in the GUI, it is disabled.
If it worked temporarily after a factory default, then it does not sound like a firmware bug. How do the two devices connect to the router?
