on 01-08-2020 10:11 PM
My Activation day is today and have received an email from TalkTalk to say broadband is live.
Router is just flashing orange... Is this normal? How long will it do this before connecting?
on 19-08-2020 07:16 AM
Hi martagd99,
I'm sorry to hear this. Please can you create your own topic and we'd be happy to take a look at this for you.
on 18-08-2020 12:46 AM
It happens the same to me, it was supposed to go live today but it didn't! Can you help me? @Debbie-TalkTalk @Karl-TalkTalk
on 05-08-2020 08:40 AM
Hi Tom
I've completed a further line test which hasn't detected any faults.
Have you tested with the phone directly at the test socket, with the router removed from the line? Was the no dial tone fault still present in this set up?
on 03-08-2020 03:05 PM
Hi Karl,
No router is still the same orange flashing, phone connected now but with no dialling tone and not taking incoming calls. Our supposedly number just rings and rings!
Tom
on 03-08-2020 02:41 PM
I'm showing a connection currently, is all ok now ?
on 02-08-2020 07:20 AM
Thank you. Have turned off the router this morning and still just the same flashing orange light. Will have to contact support today
on 01-08-2020 11:17 PM
Hi @William121 ,
The router should change to a solid white light as soon as your line is switched over to fibre, TalkTalk always say that it can take until midnight for everything to happen, so would be worth leaving it until after midnight.
If it is still flashing in the morning then try switching the router off for over 30 minutes and then switching it back on.
The staff on this forum won't be around until Monday now, so you may get faster support tomorrow by using the live chat or phoning up, however the staff on this forum will be able to help next week if you are still having problems.
