on 05-09-2020 07:51 AM
Dues to signl strength Ive a dded a second router to my wifi setup. I have changed the wireless mode , channel. security mode,and password to match the TT router. I have assigned a fixed IP address to differentiate form the TT Router. My computer and phones connect OK but other items such as TV games consoles Hive ect are having problems. If you reset the smart TV a couple of times it seems to work, but the next day its dropped off again Im not technical so looking for an easy solution even if it requires buying new kit. It seems there are issues with NAT DHCP and MHZ settings/allocating IP addresses.
on 06-09-2020 04:28 PM
@RJpad You have a few options depending on what you want to achieve.
I dont think the 2nd router in its current configuration is helpful.
Do you want to have the same WIFI SSID through the home ? In which case a Mesh System (whole home) or Wifi extender (targeting one area) is what you need.
If all you need is a WIFI signal for static devices such as TV and games console, an access point may be enough.
You Asus is capable of being turned into an Access Point.
https://www.asus.com/support/faq/1015009
Extenders and Mesh Systems too many to choose from.
Example of an Extender
https://www.tp-link.com/uk/home-networking/range-extender/re650/
Example of mesh type system
https://www.synology.com/en-uk/products/MR2200ac
on 05-09-2020 10:47 AM
If you are not using port forwarding, you do not need DDNS.
on 05-09-2020 09:44 AM
sorry missed the last part of your answer.
ve used extenders in the past but if you have different witing within the propwerrty due to extensions they have weakened the signal. A mesh sound a much better and simoler option any recomendations to work with the TT router ?
on 05-09-2020 09:38 AM
1) it is a net gear ASUS-DSL-AC52U dual band
2) do you mean this web access mode currently ticked no
Enable Web Access from WANPort of Web Access from WANAuto LogoutEnable WAN down browser redirect noticeAllow only specified IP address
Yes No |
HTTP: |
min ( Disable : 0 ) |
Yes No |
Yes No |
05-09-2020 09:29 AM - edited 05-09-2020 09:34 AM
Just to make sure I understand..
1. What make/model is the 2nd router?
2. Does your 2nd Wifi Router have an Access Point mode? If so, this is what needed.
With two wifi routers best setup with different SSID.
If you want the same wifi SSID across you Wifi system( same wifi names), you would need to get a Wifi extender or a WIFI Mesh system.
on 05-09-2020 09:11 AM
Hi.
Your setup is more complicated than mine and in all honesty above my level of knowledge, DDNS and all that !
Hopefully one of the Community Stars, @KeithFrench can take a look at this topic and offer his sage advice.
on 05-09-2020 08:44 AM
martswain thnaks
Ive now disabled DHCP on the seond router but it has lost wifi connection and showing DDNS do i need to enable this
This router may be in the multiple-NAT environment and DDNS service cannot work in this environment.
Enable the DDNS Client?
Yes No |
on 05-09-2020 08:00 AM
Have you disabled DHCP on the second router ?
It's effectively only acting as as access point, IP addresses can only be allocated by one device, your TT router.
For the access point, use different SSIDs and WiFi channels from the TT router to prevent interference.
For devices in fixed locations such as TV, Hive and consoles you'll then be able to connect to the best signal in that area.
@KeithFrench , did I miss anything ?
