Amazon fire stick not connecting to their server
Heather2019
Message 38 of 38
Ever since I joined TalkTalk, my fire stick hasn't worked.  TalkTalk blame Amazon and Amazon blame TalkTalk.  I've had the fire stick replaced and spent 2 hours on the phone to TalkTalk and still not resolved.  The fire stick connects to the internet with a good/very good signal, but can't connect to the Amazon server.  BUT when I use my phone as a hotspot, the fire stick connects with their server and will play movies.  This tells me that it's something wrong with my Hub router.  Is there something in the settings on my Hub stopping my fire stick from connecting to the Amazon server?
37 REPLIES 37
Message 21 of 38
Hi Heather
An update has been scheduled.  Can you power off the router at the mains for 30 seconds then power back on.  When the router is online it should pick up the firmware update.
Please let me know when you have done this and I'll check.
Message 22 of 38
Hi Heather.
Still unable to connect to the router to update the firmware.  I've emailed our device manager to see if he can schedule an automatic update of the router at next reboot.
I'll let you know soon.
Message 23 of 38
I have factory reset the hub
Message 24 of 38
Hi Heather,
Thanks for the update. I've tried to update the firmware to the latest version, however this was unsuccessful. Could you factory reset the router and let us know once this has been completed and we can try this again?
Message 25 of 38
Hi. I have. Not having any joy with it. Went onto the hub dashboard and it says under MAINTENANCE in the software update that to update I need a software image file??  The version currently on the hub is SKG4K10001400t
Message 26 of 38
Hi Heather2019,
How are you getting on, have you received the router yet?
Message 27 of 38
Channel 1 or 4
Message 28 of 38
Hi, Just out of interest which wireless channel are you using?
I had the same issue with my firestick when I used channel 11 but any other worked fine.
Message 29 of 38
No Problem 🙂
Should arrive in a day or two, give it a test and let me know.
Message 30 of 38
Thank you. Fingers crossed
Message 31 of 38
Ok, replacement router on the way so we can see if it is a hardware issue.
Message 32 of 38
Hi. I have done the pin reset and still no joy
Message 33 of 38
There will be nothing in the router firewall settings that would stop this.
I've both a firestick and chromecast stick at home using a Hub without issues.
Did you try the pin reset - if this has hailed then I would suggest we swap out the router just to rule the hardware out.
Message 34 of 38
Hi Karl
I have the Wi-Fi Hub. Have changed the DNS as suggested, and still no joy. Have also changed the names of the 2.4GHz and 5GHz to see if that helps too - still no joy.  Is there something in the firewall that may be stopping it contact the Amazon server?
Message 35 of 38
What model router are you using ?
Have you tried a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
Give this a try and if not working, log into the router and change the DNS to 8.8.8.8  &  8.8.4.4 and see if this helps.
Message 36 of 38
Hi Chris
Still not working.  Even disconnected the fire stick at the same time for it to reset and still no joy.  I had no problems with my fire stick connecting when I was with my previous broadband provider.  Regretting changing to TalkTalk.
Chris-TalkTalk
Message 37 of 38
Hi Heather2019,
Welcome to the Community
Can you first of all switch your router off for at least 30 minutes then switch back on and retest - please let us know how you get on
