Amber light still flashing 12 hours after email saying line was ready
Willbrown91
Message 22 of 22
Got my email this morning, around 7:30, plugged everything in and turned router on. It's been nearly 12 hours and the light is still flashing amber, not even amber/white, should it take this long for first time setup? Or is there a connection issue? Line issue? Or something else?
21 REPLIES 21
Message 1 of 22
Hi Willbrown91
No I would suggest leaving everything connected in your normal set up.
Message 2 of 22
Ok, thank you. Should I disconnect everything until then?
Message 3 of 22
Hi Willbrown91
I have arranged the engineer visit for 16/05 AM (8am - 1pm) This was the first available appointment.
Message 4 of 22
It will be a home visit. If you'd like us to arrange the engineer can you confirm:
Message 5 of 22
Yes I'd like it. I need to be able to get online to do work. Would this be a home visit or a remote engineer?
Message 6 of 22
OK thanks. If there's still no dial tone with the telephone connected to the test socket then we'll need to arrange an engineer visit. If you'd like us to do this please let us know and we'll confirm some details
Willbrown91
Message 7 of 22
I have removed the cover and attached the phone directly. I'm still getting nothing
Message 8 of 22
That's the one where you remove the cover and attach inside correct? If so, I did this earlier when I saw Michelle's reply. I will do it again though
Message 9 of 22
OK, have you tried connecting your telephone to the test socket, if not then can you give this a try
Message 10 of 22
It's a master socket 5c with the removable part to get inside
Message 11 of 22
Could you take a look at the following help article and let me know which type of master socket you have - Your guide to main phone sockets - TalkTalk Help & Support
Message 12 of 22
I have just the one, and it's plugged in a socket labeled as the master socket
Message 13 of 22
Hi Willbrown91,
How many telephone sockets do you have? Do you just have the router and one telephone connected?
Message 14 of 22
I'm getting nothing from the phone through the filter or directly in the socket
Message 15 of 22
I'm sorry to hear this. The line test is detecting a potential voice fault. If there is no dial tone at the test socket then please let us know as we will need to raise the voice fault first as this will affect the broadband connection.
Skynet_TX
Message 16 of 22
Yep, for it to not be connecting yet feels like something is wrong, it would not normally be this late without getting the amber/white light
Willbrown91
Message 17 of 22
Ah, so something could possibly be wrong as it's not gone to the amber/white light yet? I'm going to grab a phone and give the phone a try
Skynet_TX
Message 18 of 22
Yeah, it can in theory take until the end of the day, but usually you would expect to get the amber/white flashing light once Openreach had connected you up, rather than the amber flashing light you are seeing. But if you can get a handset then calling 17070 would be good, to make sure the line works and has the phone number shown in My Account.
Willbrown91
Message 19 of 22
I will try the getting a phone and testing for a dial tone.
I've spoken to an agent through the web chat and they have said it can take a whole day from the activation for everything to be fully connected with the line. So I'll give it until tomorrow morning before trying everything else.
Got thrown off by the email saying it would only take a few minutes after plugging the router in.
Skynet_TX
Message 20 of 22
Hi @Willbrown91,
Can you ensure that the cable that connects the router to the phone socket is firmly attached.
Can you ensure that you have used the new cables and microfilter (if required) supplied with your router to connect it to the phone socket.
Also, if you have a landline phone can you check to see if that is working normally (i.e. you have a clear dial tone and no noise on the line). Can you also dial 17070, this will read back the phone number of the line, can you ensure this is the number you expect (i.e. the number displayed in 'My Account').
Have you tried switching the router off and back on, or you could even try a factory reset by holding in the reset switch on the back for over 10 seconds.
For one of the TalkTalk Support Team on this community to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is to be provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk Support Team on this community can see your profile details).
@fr8ys Ooops, we were both replying at the same time !!
