Any problems in LA14 2EP?
FranRey80
Message 8 of 8
I am a new costumer,  start the 3rd of December,  I had Internet 5 hours and the line came down,  the costumer service said they are trying to fix it 3 days ago....
I can make and receive calls the problem is the router,  the light is flashing orange,  someone knows anything? I changed the filter 3 times, restart the router 20 times and nothing,  but the worse is the costumer service doesn't help.
7 REPLIES 7
Message 1 of 8
Hi Fran,
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 8
Nothing keep waiting.....
Message 3 of 8
So what did the health check say?
Message 4 of 8
Absolutely bullshit.
Message 5 of 8
You need to give them time to check what is wrong and repeatedly switching the router off will give confused readings. Don't touch it now till you get a reply.
Staff reply from oldest to newest posts, not the start time of your thread.
Message 6 of 8
I tuned it off the last time 2 hours and nothing, if that problem persist I'll change with another provider...
Gliwmaeden2
Message 7 of 8
Leave the router off for fully 30 minutes and then, leave it on!
You shouldn't do repeated restarts: not more than one in a day so you must leave it on after the latest reset until you get a response from staff, @FranRey80.
Please complete your community forum profile details. Go via your avatar/name; settings; launch profile wizard; make sure you put in your Talktalk landline phone number and a fallback mobile phone number; click finish to save.
It could take a couple of days to get a reply from TT staff after they come back on Monday.
Best not to post further before getting a response, to keep your thread moving forward in the workflow.
If you can reach them through mobile data, try Chat meanwhile, to keep Talktalk informed about the issue. Core hours 9am-6pm from links around the middle of this page:
https://community.talktalk.co.uk/t5/Articles/Our-update-on-Coronavirus/ta-p/2468300
