Anyone suggest an alternative fibre 150 ADSL/wifi router?
valleyboy1975
Message 11 of 11
I have fibre 150 installed and have the standard talktalk WiFi router which is connected to the BT fibre 150 modem
The WiFi in the house is not great and does drop, we have multiple phones, tablets, Sonos speakers etc
I know ASUS make specific gfast(fibre 150) specific combined adsl modem/WiFi hubs but can anyone suggest others?
I’ve read lots of reviews and they seems sporadic and non really stand out.l and it seems a minefield.
Besides having better WiFi I like the idea of taking the BT gfast modem
out of the equation and plugging straight into the new modem aswell.
thanks
10 REPLIES 10
bigkenny
Enlightened One
Message 1 of 11
What you could do to get all round wide wifi is maybe use some spare old routers (or buy newer ones) and have these others in bridge-mode. I have a total of 3 routers dotted round my house the 2 slave routers are fed by cat5e cable external from main No 1 router. All have different sidd names also 2.4 GHz and 5 GHz chs. all have different names but all same Password. It seems to work great coverage all round the house and garden are good with no black spots
Message 2 of 11
Thanks for the reply and sorry for late reply!
Message 3 of 11
Message 4 of 11
Cheers all, out of interest our house has no physical barriers to male the WiFi signal worse, so what ‘tweaking’ can be done with the existing talktalk router.
Cheers
Message 5 of 11
OK, it's entirely up to you. But do bear in mind that no two domestic setups are alike. Please let us know how you get on.
Message 6 of 11
Cheers both, I’ve got the latest super router, I want to get a new one as a grind has and it totally transformed his WiFi
Message 7 of 11
@valleyboy1975 Rather than searching in a very narrow and largely unproven market perhaps you could look at simply trying to improve your wifi performance? Which TalkTalk router do you have? Both Hub models are quite capable devices with a bit of fine tuning. Or if your property poses specific issues there are other ways of improving coverage.
Message 8 of 11
Message 9 of 11
Make sure you search specifically for G.Fast compatible modem/routers, which are few and far between at the moment. Many of those listed as simply fibre/VDSL will be like the TalkTalk model and require an external modem.
Birchcroft
Message 10 of 11
@valleyboy1975 it really comes down to your budget and the functionality you want.  I suggest you look at some of the online review sites, eg:
https://levvvel.com/best-fiber-optic-modem-router/
https://www.expertreviews.co.uk/networks/wireless-routers/1403819/best-wireless-routers-improve-your...
https://www.lifewire.com/best-cable-modem-router-combos-to-buy-4082541
These tend to restrict themselves to consumer products.  In addition there are more business focused products from companies like Billion and Draytek.  Finally Fritzbox which is used by the ISP Zen is worth a look.
https://en.avm.de/products/fritzbox/?source=post_page---------------------------
https://www.zen.co.uk/broadband/broadband-router
