Back to flashing orange light :( help appreciated
temooriqbal
Message 15 of 15
I had a problem of a flashing orange light on my router and no connection. This was fixed by an Openreach engineer visit and a new router. Since then it has been working fine, but today one device was unable to connect properly - only got 'connected - no internet'.
I went to the router homepage and changed the 5ghz SSID name to [networkname]5GHZ. This is something I'd done before with no problems. Upon doing that, however, all devices disconnected and the router is now back to a flashing orange light.
Could someone at TalkTalk cancel the SSID renaming that I did? And is there any other solution for the overall problem in general?
14 REPLIES 14
Message 1 of 15
Hi temooriqbal,
How is it today, is it still not working?
temooriqbal
Message 2 of 15
Hi, it was working ok yesterday, but today it has got progressively slower throughout the day, and now has stopped working completely 😞
Less than 12 hours of actual use, not great.
Please could you now book an engineer visit for asap?
Message 3 of 15
Hi temooriqbal
How was the connection last night? Is this still working ok?
Message 4 of 15
Hi temooriqbal
I'm so glad to hear this.
If the fault does re occur then we will arrange an Openreach engineer visit.
Message 5 of 15
Hi Debbie, I did, and after a couple of resets it SEEMS to be working! I'll update this thread if it fails again, but looks ok for now (fingers crossed). Thank you!
Message 6 of 15
Hi temooriqbal
Apologies for this.
Can I just check, did you connect the new router, filter and cables directly at the test socket?
Message 7 of 15
Hi, the new router arrived, but it has not solved the problem. The issue is the same - flashing orange light, no change.
Please could you book an engineer visit, as that was the only thing that worked last time when we faced the identical problem.
Message 8 of 15
Hi  temooriqbal
Apologies for this. The router is on its way, please allow 24-48hrs for this arrive.
Message 9 of 15
Hi Debbie,
Yes, if that's the next step then please send another router by next day delivery.
Ideally it would be great if I didn't need a new router every couple of months! So interested in a long-term solution too, but please send a new router for now
Message 10 of 15
Hi temooriqbal
The line test is clear but detecting a potential router issue.
Would you like me to send a replacement router for testing?
Message 11 of 15
Please help! This is urgent, and unacceptable that the same problem has started happening again in just over a month since it was last fixed!
Message 12 of 15
The reset will have undone the 5ghz SSID renaming that I did, presumably. So now the problem is no longer that - it looks like it's back to the previous problem that I had, which was an issue with my connection. That was only solved by an Openreach engineer coming round. Can that be booked again please?
Message 13 of 15
Thanks Michelle, I've just tried this. It made the orange light flash slightly faster for a minute, but then it went back to slow blinking - no change. Any other suggestions? It's urgent as I need the connection for work.
Message 14 of 15
I'm sorry to hear this. Have you tried factory resetting the router and then re-setting this back up again?
Restore your router to factory settings - TalkTalk Help & Support
