Bottleneck when using GlobalProtect VPN
Junkbot
Message 2 of 2
When I run a speed test I am getting acceptable speeds, however whenever I start copying files/ downloading files while connected to the work GlobalProtect VPN the speeds drop to where it will take hours.
Any ideas, it appears to affect all devices and not just the device connected to the VPN - e.g. mobiles etc.
Thanks,
Iain
1 REPLY 1
Message 1 of 2
I've just posted on your other topic so I will close this topic to avoid confusion.
