on 31-05-2022 01:08 PM
Over the past couple of weeks my broadband connections keeps dropping out intermittently, which when working from home becomes very frustrating especially when on calls. Ran through the online tests, which state there is no issues, reset the router, tried changing channels etc., but no luck. Dropouts affects all devices - so isn't isolated too particular device. Also, TalkTalk 'Live chat' never actually opens up - not sure if others have this same problem. So reaching out on the forums for some help.
on 13-06-2022 08:50 AM
Hi Andrew
I'm just sending you a Private Message to confirm some details so we can arrange the engineer visit.
on 13-06-2022 08:47 AM
Yes, please
on 13-06-2022 08:22 AM
Hi Andrew
Apologies for this.
If the connection is dropping (wired) with the replacement router and cables at the test socket then the next step will be an Openreach engineer visit.
Would you like me to arrange this visit for you?
on 10-06-2022 05:00 PM
Actually I’ve managed to connect an old laptop directly to the router, and the internet also dropped off. So I have a problem with both wired and wireless connections. And the router flashes white and orange when it drops
on 10-06-2022 04:15 PM
As mentioned on a previous message the only devices with a wired connection are something for the Hive heating and the Sonos music system. Both of which are just hubs. My laptop doesn't have a ethernet port so couldn't connect directly anyway. I have noticed that when the internet drops, the router light flashes white and orange. And also, my wireless Sonos speakers do stop playing music. Therefore, I assuming the connection drops to the wired connection Sonos hub.
Andrew
on 10-06-2022 06:47 AM
Can I just confirm, have you noticed if the devices that you have connected wired also lose connection or are these stable? Have you noticed if any lights on the router change when this happens?
on 09-06-2022 05:08 PM
Hi, so this afternoon I've tried using each of the channels recommend by TalkTalk, and for each channel I'm still getting the same issue.
Wireless frequency Recommended channels
2.4GHz | 1, 6 or 11 |
5GHz | 36, 40, 44 or 48 |
on 09-06-2022 11:15 AM
Hi Andrew
Ok thank you. I've switched off the WIFI optimisation, please can you try a couple of different wireless channels again to see how the connection compares?
on 09-06-2022 10:56 AM
I don't have any devices wired into the router other than the Sonos and Hive boxes. The router is based at the front door of the house, so it's not a place where we would wire something into. So cannot really say.
on 09-06-2022 10:32 AM
Hi Andrew
Apologies for this. Is this also happening on wired devices?
on 09-06-2022 10:21 AM
Unfortunately, I'm still having the same issue having installed the new router. Wifi connection drops out for a few mins every now and then throughout the day, and affects different devices. So not sure what the next steps/solution is?
Andrew
on 09-06-2022 08:41 AM
Just checking back in to see how the stability has been with the replacement router?
on 01-06-2022 11:38 AM
If you start your own thread (new message), we’d love to help.
We’ve found that posting in someone else’s conversation makes it harder to follow when looking for an answer.
It’s easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
on 01-06-2022 11:33 AM
Having the same here too. Connection drops for 2-3 minutes and has happened multiple times since yesterday evening. And in the middle of file downloads. No issues within the home and happens on all devices. Probably not a prolonged enough outage to show up on TalkTalk’s own issues or outage lists. I wonder if the router is at fault but then not a regular enough occurrence. No point in running through TalkTalk tests which only try to deflect the blame towards the home customer.
on 01-06-2022 11:13 AM
No Problem 🙂
on 01-06-2022 11:06 AM
Brilliant, thanks Karl
on 01-06-2022 10:58 AM
OK, I'll get another router out to you so we can see if this is hardware related.
on 01-06-2022 10:54 AM
Hi Karl, yeah the dial tone is clear.
on 01-06-2022 10:52 AM
Broadband tests are clear, can you check the home phone and make sure the dial tone is clear, with no noise on the line.
on 01-06-2022 10:06 AM
Hi, my profile should be updated with that information now. Thanks
