Broadband disconnects when call received on TalkTalk line.
Evazan
Message 10 of 10
I upgraded from regular slow broadband to Fiber 65. The speed is great, but I have a problem.
If the phone rings due to an incoming call, the internet drops.  If I make an outgoing call the internet stays on until I hang up, then it drops.  This happens even when my computer is turned off.
The Router is connected to the main socket and so is the phone. I have used the new filter that comes with the router.
This didnt happen before on the regular 3.5mbps broadband only since the upgrade.
Any ideas how to fix it?
9 REPLIES 9
Message 1 of 10
Hi Evazan
Would it be possible to test with a different phone/handset? (just for testing purposes)
Message 2 of 10
@Evazan have you tried a different phone handset ?
Message 3 of 10
The phone is working fine and had no problem with disconnects before the switch to Fibre broadband. Its only since the upgrade that this problem started.
Message 4 of 10
@Evazan
All that points to an incorrectly filtered internal line setup or the handset/answering machine having a fault.
Message 5 of 10
Hi.
I unplugged the phone and dialed the number from a mobile. It obviously wasn't answered and did not disconnect the internet.
The internet drops only when I receive a call that is picked up by me or the answerphone, or if I make an outgoing call then I hangup. Then the internet drops off when I disconnect.
Its connections and disconnections that causes the drop.
Message 6 of 10
Hi Evazan,
Thanks for trying this. Can I just confirm, if you unplug the phone so there is only the microfilter and router connected to the line and then call the line, does the connection still drop?
Message 7 of 10
I swapped to new filters yesterday and it hasn't made any difference. It still disconnects the internet when I get a call. Either on connection or when I hang up.
Its now plugged into the test socket with the filter.
Message 8 of 10
Hi Evazan
I've completed a line test which hasn't detected any faults.
Is the router currently connected at the test socket with a new microfilter?
Skynet_TX
Message 9 of 10
Hi @Evazan,
Have you tried using the old Microfilter that you used on your previous package, just to see if the fault is with the new microfilter.
Then they will hopefully be able to respond to this post within a working day or two.
