Broadband keeps disconnecting
Gazzza
Message 37 of 37
Hi we have not long joined about a month ago  we are happy with the speed we are getting but we keep getting disconnecting this happens once or twice a day everyday. I have done all the checks and it says everything Is all OK but it is not we have all the same devices connected to it as we did with our last provider any advise?
36 REPLIES 36
Message 1 of 37
Tests are still picking up a fault and an engineer is required.
I'll drop you a PM to confirm some details.
Gazzza
Message 2 of 37
Hi I belive I have plugged it now in to the test socket with filter attached
Message 3 of 37
Hi Gazzza,
Ok thanks for the update and please let us know how you get on.
Gazzza
Message 4 of 37
Hi got to look for filter so I can plug it in I will have. To do that tomorrow
Message 5 of 37
Hi Gazzza
Would it be possible to connect it at the test socket when you get home and leave the router, phone and filter connected there until we have tested the line again?
If the same fault is still detected then the next step will be to arrange an Openreach engineer visit to the property.
Gazzza
Message 6 of 37
Unfortunately I am at work at the moment and not at home
Message 7 of 37
Hi Gazzza
This master socket should have a test socket underneath the face plate. Would it be possible to connect the router at the test socket so I can run another line test in this set up?
Gazzza
Message 8 of 37
Openreach came about 8months ago and put us a new box I belive it's a master socket 5c and just advice our phone is clear
Message 9 of 37
I'm sorry to hear this. I've run a test on the line which has detected a possible issue towards the property. Is your router currently connected at the test socket? Is there any noise on the voice service?
Gazzza
Message 10 of 37
So here we go a again for the last week the Internet keeps cutting on off even your app said there was a problem but text messages back to me say its OK but its not IT KEEPS CUTTING off and its getting a bit annoying now p
Message 11 of 37
So not only has your Internet not been good since we have had it you now want to put it up by £2 month not good enough
Message 12 of 37
Hi here we go again twice yesterday 12\2 and one today so far I have had 2 physically reset the the Internet it cuts off and flashes orange till you turn it off and back on I am now getting a bit annoyed as we have had this problem from the 1st week we switched over to you and like I have said before we never had this issue with our last provider oh and also our router needs an update
Message 13 of 37
So far so good 👍
Message 14 of 37
Hi Gazzza,
Thanks for the information. There was a line profile change on the 31st, how has it been since the drop on the 1st?
Message 15 of 37
Hi was about 15 min 20 min and again tonight 01/02 about 19.30 solid white lite but no Internet till I re set it then was fine
Message 16 of 37
Hi Gazzza,
I can see a couple reconnections over the last couple of weeks, one on the 22nd and one on the 26th. Do you feel that the connection has been dropping more than this? Do you know approximately how long was the connection down for the 26th?
Message 17 of 37
Hi its started doing this again it did it a couple of times last week and as type now very annoying when home schooling
Message 18 of 37
Hi Gazzza
That's great, thanks for letting us know 🙂
Message 19 of 37
Hi yes has been OK now for a wile thank you for your help
Message 20 of 37
Hi Gazzza
Sorry for the delay.
I've checked the connection stats and the connection appears to have remained stable since 24/12.
