Broadband speed are way below advertised speeds
GRex96
Message 14 of 14
My broadband speeds are nowhere near close to the advertised speeds. I'm paying for superfast fibre and because this house was only built 8 years ago, I was promised close to 80mbs download speed whilst I'm only getting 30mbs max on a good day though a wired connection.
My speeds were better before I upgraded to super fast fibre a few months ago. Not only that my Internet goes out several times a day. Another issue is my Internet cuts out every time I get a call to the landland phone. It has a filter installed.
I also believe my speeds are being capped as shown by the downstream maximum rate of 47231Kbps.
I've had to resort to talktalk forums because I've called numerous times and they have not been been able to help.
13 REPLIES 13
Message 1 of 14
Glad our team was able to help.
GRex96
Message 2 of 14
Hi Debbie,
The engineer just finalised his visit. The engineer managed to fix the issue and I am now getting full 80mb/s download and 20mb/s upload. Thank you for resolving the issue.
Message 3 of 14
Hi GRex96
I have arranged the engineer visit for 06/08 AM (8am - 1pm)
GRex96
Message 4 of 14
Hi Debbie,
Yes I can confirm the possibility of engineering charges. I should be available for either am or pm.
Message 5 of 14
Hi GRex96
Thanks for confirming your details.
Please can you also confirm potential engineer charges and provide your availability for this visit AM and PM?
Message 6 of 14
Hi GRex96
GRex96
Message 7 of 14
Hi Debbie,
Yes I would like an engineer visit.
Thank you
Message 8 of 14
Hi GRex96
I've checked the connection stats and the line is in sync at 38.3mb.
If you have tested with a different router at the test socket for 48hrs then the next step will be to arrange an Openreach engineer visit.
Would you like me to arrange this visit?
GRex96
Message 9 of 14
Hi Michelle,
My broadband speeds have not changed. I've been onto the service centre to run a test on the service and it states there may be a problem with the service. Apologies for the late reply I've been really busy.
Message 10 of 14
Thanks for connecting the router at the test socket. Please could you post back here tomorrow and we can re-check the connection stats again to see if DLM has made any changes to the speed now that the router is connected at the test socket.
GRex96
Message 11 of 14
Hi Michelle,
Both phone and router are connected to the microfilter which is connected to the test socket .
Message 12 of 14
I've run a test on the line now which is clear. If the main socket has a test socket then if possible please can you connect the microfilter, router and phone at the test socket for at least 48hrs so we can see if DLM makes any changes to the sync speed please.
Skynet_TX
Message 13 of 14
Hi @GRex96,
The fact that your upstream is showing as 20000 proves that you are on the faster Fibre 65 package, so that can theoretically give you speeds of 80000 'down' (although the actual speed you can get is totally dependent on the length of your phone line). If you are having regular drops of connection then this can have a knock on effect on your speed as the equipment in the street cabinet will reduce your speeds in an attempt to stabilise your connection. So it would be good to get the cause of the drops investigated, as resolving that may then allow your speeds to increase.
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The TalkTalk staff on this community will also be able to help, they will hopefully be able to respond to this post tomorrow.
The maximum downstream rate being lower than you expect does not mean your connection is being capped, that number is just the fastest speed your router thinks it would be possible to connect at if there was nothing else limiting the connection speed (and the DLM equipment in the street cabinet could well be limiting your connection speed if your line is dropping a lot). So the fact that number is much lower than you would expect may well just be due to the fact there is some issue with the line (possibly causing the drops of connection too).
