Broadband upgrade
Xetog
Message 3 of 3
I upgraded from Faster Fibre (35mbs) to Fibre 65 (65mbs) on 22nd November, but so far no increase in speed.  I assume that this is adjusted at source, so who do I contact to get the change made?
Pensioner on line
Message 1 of 3
Hi Xetog
I've checked the connection stats and your line is in sync at 38mb.
What speed were you receiving before you upgraded to fibre 65?
Skynet_TX
Message 2 of 3
Hi @Xetog,
What speed did you used to get on your Fibre 35 service ?
Are you testing the speed wired or wireless ?
If you log into your router to check your sync speed does this show the faster speeds you would now expect ?
If so, try switching your router off for over 30 minutes, this will get you a new session in the street cabinet and should get your wired throughput speeds up to something close to your sync speeds.
