on 09-09-2020 08:02 PM
Hello there
My broadband is extremely slow. It has got slower following some recent power cuts.
It has been suggested that it could have affected the line management dynamics and if the DLM was reset, this could improve things.
Please could you investigate and optimise the speed of my broadband.
Thank you
on 09-11-2020 06:20 AM
Hi Offley
I'm really sorry for the delay.
I've checked the connection stats and your line is in sync at 1.4mb.
How has the connection been since your last post?
on 04-11-2020 05:29 PM
Good afternoon Debbie
I go the broadband speed tested yesterday with the new router and it was
1.1MB download, 0.8 upload
so much improved and a lot easier to use the internet with these speeds.
Thank you for sending the new router.
on 26-10-2020 01:42 PM
Hi Offley
Let us know how the connection/speed compares with this router.
on 26-10-2020 01:26 PM
Hi there
We could see if it works.
I'll give anything a go to get better broad band speed.
on 26-10-2020 08:10 AM
Hi Offley
Apologies for this.
Would you like me to send a replacement router for testing to see how the connection compares?
on 23-10-2020 12:36 PM
Have the optimal speed for a bit, but then it seems to deteriorate to the levels I have given you before. Were told it is being a long way from the box.
Do not have a test socket next to the master socket.
Hope this helps
on 23-10-2020 11:01 AM
Hi Offley,
I've optimised the connection again to try and increase the speed a bit further. Just to confirm, what speeds were you originally receiving before the speeds dropped? Does your master socket have a test socket?
on 22-10-2020 11:38 AM
Hi there
I have had the speed checked again and it is 0.8M download, 0.4M upload
Can you get it higher please.
on 14-09-2020 08:57 AM
Hi Offley,
I'm sorry for the delay. I can see that DLM has increased the speed this morning. How is your speed at the moment? What speeds were you receiving prior to the speed drop?
on 11-09-2020 07:47 PM
Hi Debbie
The broad band speeds are:
1.1mb download
0.3mb upload.
on 10-09-2020 10:21 AM
Hi Offley
Ok, no problem 🙂
on 10-09-2020 09:53 AM
Hi Debbie
I will have to wait for one of the children to find it for me.
I will let you know, but it may not be today.
thanks
on 10-09-2020 09:24 AM
Hi Offley
How is the speed now following the line optimisation?
on 10-09-2020 09:18 AM
Thanks Debbie
The previous speeds were:
Upload 0.6mb
dowload 0.3mb
on 10-09-2020 07:50 AM
Hi Offley
I've reset the data port and optimised your connection and the sync speed has increased to 1.5mb.
What speed were you previously receiving?
