Broken stand at back of WiFi hub
Mill_5
Message 8 of 8
I received my talktalk router for your broadband on the 29th of November, when I brought it out of the box to set it up I noticed the stand at the back of the WiFi
hub was broken and the stand falls off the hub. Would it be possible to get
a replacement stand for the back of the hub? I have tried contacting your customer support but to no avail. I haven't gotten a reply from them to resolve this and it's been a week since I emailed about this.
7 REPLIES 7
Message 1 of 8
Hi @Tangerman2010
Please can you create a new thread, we can then look into this further.
Message 2 of 8
@Debbie-TalkTalk
I found this with my hub that arrived as well, are you able to send out a replacement to myself?
Let me know if you need any more info.
Many thanks.
Message 3 of 8
Hi Mill_5
The replacement WiFi Hub is on its way, please allow 24-48hrs for this to arrive.
Debbie 🙂
Message 4 of 8
Hi Debbie
Yes that will be great.
Thank you for your help!!
Message 5 of 8
Hi Mill_5
I will send the router to the address linked to the telephone number in your Community Profile, will this be ok? (Please do not post the number on this thread as I can see this in your Community Profile)
Mill_5
Message 6 of 8
Hi Debbie
That would be great thanks.
Do I need to confirm any of my details?
Message 7 of 8
Hi Mill_5
Apologies for this.
I can send a replacement WiFi Hub and a returns bag. I'm unable to send just a stand for the hub. Will this be ok?
