Can not connect phone to wifi
Cookster
Message 21 of 21
Had a Sagemcom Fast 5364 Router sitting in cupboard since it was delivered 2 years ago. Decided to use it and set up seemed okay until I tried to connect my Samsung j5. After several tries using password and wps I cannot connect phone due to ' incorrect password ' or 'authentication error'. Reverted back to old router.
Anyone any ideas
20 REPLIES 20
Message 1 of 21
Hi Paul
I'm not sure why the connection is not working the same with the new router.
If you do experience any issues with your current router then please let us know.
Cookster
Message 2 of 21
Yes the HG633 is working amazing compared to the new routers. Page loading is almost instantaneous.
thanks
Paul
Message 3 of 21
Hi Cookster
I'm not sure why you experiencing this issue with the new routers.
Is the HG633 working ok at the moment?
Cookster
Message 4 of 21
Hello. I have switched back to my old router as I was having so many problems I could not even reply to your posts as pages wouldn't load. Thanks for your help but I can not be bothered to waste any more time on some thing which shouldn't be as difficult to do as it has turned out. I might as well as had an old dial up connection with the speed of the new routers. Sorry to waste your time and thanks again for trying to help.
Message 5 of 21
Hi Cookster
Is this on the wired device? I'm just checking incase it's just the wireless affected.
I would advise splitting the SSID's (I have done this on my router and I'm using the same router as you)
Message 6 of 21
Hello, I have connected the new router and seem to have connection across all devices although I have had to restart just about everything to get a connection and page loading is much slower than old router normally on old router pages load straight away but not with new one.
Message 7 of 21
I've just checked but I can't connect to the router. Did you have a chance to change over the routers?
Message 8 of 21
Cookster
Message 9 of 21
The router was and is always connected by a wired connection which should take priority over wifi. I will reconnect the new router again tomorrow morning as in Thursday 1st July for you to be able to connect to it.
Message 10 of 21
Hi Cookster
Would it be ok to connect the Huawei WIFI hub so I can connect to the router?
Please can you also try and connect wired?
Cookster
Message 11 of 21
I believe so as wifi seemed to be getting turned off.
Message 12 of 21
Hi Cookster
Did you also experience the issue with wired connections (on the new Huawei hub)
Cookster
Message 13 of 21
The router was huawei although they look the same. My old router is huawei and i am not getting any issues with that one. The new ones are giving me problems.
Message 14 of 21
Hi Cookster
Was the replacement router another Sagemcom hub or a Huawei WIFI hub?
Message 15 of 21
Thank you for the new router. However this doesn't work properly either. I don't understand what the problem is. Phones connected ok and computer tells me that I am connected both ethernet and wifi but the router is so slow. One minute I can get a page up the next they won't load and it tells me I got no internet connection whilst everything else tells me I have. Have put my old talktalk router back and that works super fast with no problems so I am lost for whats going on.
Message 16 of 21
I am seeing a lot of errors on the wifi side.  I've another router on the way so we can rule out a hardware issue.
Cookster
Message 17 of 21
Have added phone number
Message 18 of 21
Hi Cookster
Please can you add your TalkTalk landline number to your Community Profile.
Message 19 of 21
Sorry for length of time to reply. Reconnected Sagemcom router and phones connected okay. Problem now is having connected to computer via cable I can not get an internet connection with my pc either wired or wifi. Invalid ip configuration is one error message I get. Reconnected old router with no problems what so ever so don't understand what is going on.
Message 20 of 21
Hi Cookster,
I'm sorry to hear this. What version of firmware is currently on the Sagemcom router?
