Can't setup 192.168.1.1 as internal host in port forwarding
YuTalk
Message 8 of 8
I want to configure the TalkTalk Wifi Hub, so you would be able to access the router configuration page from 192.168.1.1 remotely via the internet through port forwarding.
But when I enter "192.168.1.1" inside Access Control->Port forwarding->Add rule->internal host, it gives me an error saying it's an invalid IP address, while it's a valid IP address for the router itself.
How do I fix this?
7 REPLIES 7
Message 1 of 8
Hi @Anonymous
I realise that, but the original question raised by the OP that I was trying to answer, was that TalkTalk does not allow remote access to the router, direct from the internet.
RDPing to a PC on the local LAN will of course allow access to the router like that, if the OP has a PC on 24/7.
Message 2 of 8
Errr
It is not remote access if it comes across your internal network, from a PC in the lounge to the router under the stairs.
You are watching what the local PC has on its screen via RDP or similar.
Virgin Media, Microsoft et al;  will remote into your laptop and run things from there on occasions.
So it can be done, also before I let them in I put a simple password in place, then replaced it with a stronger one.
Message 3 of 8
TalkTalk prohibits remote access to the router on the grounds of your safety.
Message 4 of 8
I would try an RDP (Remote Desktop Protocol) connection to a PC / Raspberry Pi etc, then open a browser and try 192.16.1.1.
However I would be wary of changing settings that might reset the router and leave it hanging with no connections at all.
Message 5 of 8
You would need to know you Public IP address, which is not fixed on a TT home service.
Even then, I'd guess that any incoming traffic aimed at the router interface would be blocked by the firewall.
I am getting out of my depth here, but @KeithFrench will know the answer I am sure.
Message 6 of 8
Then how do I access the router configurations externally?
Message 7 of 8
You won't be able to as that is the IP address of the router. The whole point of port forwarding is that you forward the port to a device connected locally to the router, not the router itself.
