Cannot connect to work VPN (L2TP) using Sagemcom-FAST5364 Router
CourtjCassidy
Message 8 of 8
Hi there,
I have had issues with connecting to my work VPN using Sagemcom-FAST5364 router. The IT team have been trying to work on a fix but have informed me that they are unable to do anything, and it will require either a new router from yourselves or an update to my current router which I can see requires one.
Would you be able to either update my current router or send me out a new one that will be compatible with the VPN as soon as possible please?
All the best,
Courtney
7 REPLIES 7
Message 1 of 8
No Problem 🙂
Message 2 of 8
Hi Karl,
That would be amazing, thank you so much!
All the best,
Courtney
Message 3 of 8
The Sagemcom does work with most VPN services, but i'll get the other model Hub out to you and see if this is better.
Message 4 of 8
Hi Debbie,
Thanks for updating the fireware. I have just retested and sadly am still unable to connect to the VPN. Any suggestions?
All the best,
Courtney
Message 5 of 8
Hi Courtney
I have now updated your router firmware version, please can you retest and let us know if you are now able to connect.
CourtjCassidy
Message 6 of 8
Hi Michelle,
Thanks for getting back to me so quickly. I have just added that to my Community Profile. Let me know if you need anything else from me.
All the best,
Courtney
Message 7 of 8
  • TalkTalk Telephone number
