Changing Router Password
IzzyGil
Message 2 of 2
@members How do I change the password for my router without compromising security? I know I can do this manually but I have the message "weak security" on my devices. Please advise?
1 REPLY 1
martswain
Message 1 of 2
The "weak security" does not refer to the actual password, but to the encryption type being used over the WiFi connection.
EXACTLY what model router do you have ?
If you are using Apple devices, read this topic
https://community.talktalk.co.uk/t5/Fibre-Broadband/Weak-Wifi-security-after-update-to-ios14/m-p/263...
