Channel changing to busier channels despite setting a channel manually
GreedySouper
Message 8 of 8
Hello, I'm finding daily that my 2.4ghz channel and sometimes my 5ghz channel are changing from the channel I've set it to. Whenever I use my phone to see the current channel and the traffic, it's always changed it from the channel it was set to (which is the quietest in my area) to one that is busier. The 5ghz will change channels, sometimes to another empty channel, however it has also set it to the same channel as my neighbours at times when there are plenty of empty alternatives. Could you please turn off the setting that causes it to change automatically please? Many thanks!
7 REPLIES 7
Message 1 of 8
Hi @GreedySouper
Have you had any issues with the wifi channels changing etc ?
Message 2 of 8
I did set this function to read only directly in the router.  I can see you have manually set the wifi channel.
I've set this function to 'off' in the router, can you let me know in the next day or two if the wifi channels change.
Message 3 of 8
Hi, it seems to have not made much of a difference as the channels are still changing on their own. I've manually set them to the better channels for the area and find that it's changing the channels automatically still. Did I need to reboot the router to have the changes work?
Message 4 of 8
No Problem 🙂
Message 5 of 8
Thanks, much appreciated!
Message 6 of 8
I've set this to off.  Test over the next few days and let me know if there are any issues.
Message 7 of 8
I'll ask the OCEs to disable WiFi optimisation for you.
