Completely desperate
ramon018
Message 31 of 31
I write this as a last resort as I have been chatting for 7 days, about two hours per day for nothing.
My connection keeps  dropping everyday, sometimes it's few minutes every 10, sometimes it's 10 minutes a day, or sometimes it's one hour every hour...
Every time I go to the chat they check and say its my homes fault as there's no issues in the line. How could this be possible when I haven't touched the set up made by the engineer a month ago?
The Internet light on the modem goes off, the dsl light flashes fast then slow then fast then off and all over again.
When I tell this in the chat I have been told all the time it is my fault and if I want an engineer to come and check I would have to pay for it. How is this possible? I have had issues before with Sky and when I contacted them the sent the engineer straight away..
Now I'm left without connection at all, and chats are closed, again 0 customer service.
30 REPLIES 30
Message 21 of 31
Yes please but the visit will have to be scheduled from the 27th onwards
Message 22 of 31
There will always be a condition of a potential charge, that's not to say you will be charged, but if an engineer proves the issue is caused by something the customer has done, then a charge would be applied.
So if the fault is on the line or network, then that's up to us to fix.
Are you ok to go ahead with this ?
Message 23 of 31
Yes please,  but at no charge, everytime I have been told about an engineer visit Ive been told I had to pay.
Message 24 of 31
I'm sorry to hear this. I've run a test on the line now which has detected a potential fault towards the property. If the set up hasn't changed since this was installed by the engineer and the modem is losing connection then the next step would be to arrange an engineer visit. Would you like to go ahead with this and we can confirm some details with you?
Message 25 of 31
What hub do you have from TT? And what package are you on?
If your on Fibre 35 / 65 have you tried connecting the TT Hub direct to test socket instead of connecting to Openreach modem.
Steve -
Have you tried turning it off and on again!
Message 26 of 31
And now we are back with 4 green lights but on all of our devices it shows as "connected without internet"
Message 27 of 31
I just opened the socket and this is the connection the engineer made
Message 28 of 31
Hi again, thanks for your quick and kind answers.
I have tried all kind of troubleshooting also connecting to the test socket and nothing.
And the problem is that when I get to chat with them, if there's no issue exactly and that time, for them is perfectly fine even if I have the problem at any other time
Ste_Nix14
Message 29 of 31
Have you tried running a Line test through Service centre, does this give the same conclusion as TT have stated?
Personally I had/have the same sort of issue the connection is intermittently and all tests point towards the home set up which in the it wasn't and by running a Line check every so often this picked it up as a Line fault and requested a engineer automatically. Openreach found it to be a faulty port in the cab which is still awaiting repair.
In your case have TT sent you a diffrent hub to compare connections with? Also are you connected directly to test socket?
To allow staff on here to help you ensure your profile is filled in with details such as Home phone number etc so they can locate your account.
Steve -
Message 30 of 31
Sorry to see this. Have you worked your way through the troubleshooting steps in the help article?
https://community.talktalk.co.uk/t5/Articles/Fix-a-dropping-broadband-connection/ta-p/2205305
Subject to that, if you would like the support team here to look into this for you it will help if you make sure that your personal details including TalkTalk landline number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond.
