Connecting Panasonic Dect phones to Wi-Fi 2 hub?
Ian50
Message 7 of 7
      Please does anyone know if it is possible to connect Panasonic Dect phone handsets to the Wi-Fi 2 hub to use them as voip phones? Many thanks.
Ian
Ian
6 REPLIES 6
Message 1 of 7
The Future Fibre Support Hub is your go-to resource for information, guides and LiveChat with the Future Fibre Team.
LiveChat to the Future Fibre team
Opening hours are here:  When to contact TalkTalk?
TIP - Scroll down the Future Fibre Support Hub page to GET IN TOUCH. if you don't see a blue Chat now button then pause tracker blocking in the browser, ad-blockers or similar blocking software to avoid conflict with LiveChat's operation.
Calls to the Future Fibre team on 0345 172 0074 are free from a TalkTalk home 'phone but otherwise are at a standard landline call rate or included in your UK mobile allowance.
Future Fibre Help
Future Fibre - Set up your Wi-Fi Hub 2
Future Fibre - Battery back up unit for Wi-Fi Hub 2 and ONT
GondolaVolunteer 2017-2022
  Like below to appreciate my help . . . Mark as solved  Accept as Solution
Gondola
Message 2 of 7
And I see ferguson has replied at the same time with the prerequisite for having an FTTP service from TalkTalk that is enabled for VOIP. I'll provide links for the Future Fibre team and the setup of the Wi-Fi Hub 2 for a Future Fibre with Digital Voice service.
Ian50
Message 3 of 7
I’ve connected the base station to the Wi-Fi2 phone socket but get no dialing tone, do I need some form of adapter?
Ian
Ian
Gondola
Message 4 of 7
Hi Ian50
No reason why the base station cannot be connected to the green Voice/VOIP port at the rear of the Hub 2.
The handsets themselves would need to remain paired to the existing base station as there's no DECT base station built in to the Hub 2
Message 5 of 7
I should have added that it would need to be the main base station which was connected, rather than individual handsets.
Message 6 of 7
If you have Full Fibre from TalkTalk with VOIP services enabled, then yes.
