on 23-01-2022 02:13 PM
Hello! I have TalkTak's fiber broadband and a Sagemcom rooter.
I've been with TalkTalk for about a year I think. Since I've had an iPhone 13, for about the last 2 months, I've noticed that the wifi connection on my phone 'freezes'. When I open my phone from 'sleep', the wifi symbol is there and everything looks okay and connected - but nothing happens/loads. When I switch my phone's wifi on and on again quickly, the page then loads and everything is fine. It seems to happen more when the phone has been asleep for longer. I didn't have this issue with my old iPhone. I'm not sure if it's a firmware update issue (but apparently the router updates itself automatically?!)
I don't know if this is related at all..., but when I accessed my router settings today I noticed that it was showing all the wireless devices as connected to its 2.4ghz network; none are connected to the 5ghz band. Is this right?!
on 31-01-2022 12:20 PM
OK thanks for the update, glad to hear that there's been an improvement. Do you have any issues with any of your other devices?
on 31-01-2022 11:45 AM
Hello. Sorry, I thought I'd replied last week. I've split the SSIDs and just put my phone on the 5GHz. It still does the 'sleep-freeze' thing, now and then, but it seems to be less frequent than it was before.
on 24-01-2022 07:44 AM
Hi AngusJT7LD
Sorry for the delay.
I can see that KeithFrench and ferguson have offered some advice. How are you getting on?
on 23-01-2022 04:21 PM
Try splitting the SSIDs as explained here:
Then make sure to "forget" the previous network setting on your iPhone and connect to the newly named 5GHz one.
on 23-01-2022 03:40 PM
Devices will connect generally to whichever band is giving them the best signal at the time.
As to the iPhone settings, hopefully, @ferguson might be able to help you.
