on 29-05-2022 12:39 PM
Hi, new Fibre 65 customer here.
I'm on day 13/14 of my "stabilisation" period and in the past few days my router has dropped connection completely a few times for up to an hour. The light on the Huawei router remains white but there is no connection whatsoever. My Sky Q box is hard wired to it so this is usually when I first notice, obviously there is no connection via WiFi too when router drops.
I've just moved to talk talk from being with BT for years and I can't remember the last time my BT connection dropped, I hope this isn't a regular occurrence with talktalk or I'll have to cancel.
Any help appreciated.
Richard.
on 20-06-2022 12:44 PM
Hi djrich
That's great, thank you 🙂
I have also sent you a Private Message with a link to a short survey.
Thanks again.
on 20-06-2022 12:37 PM
Hi Debbie, this new router seems fine so I'll send the old one back this week.
Kind regards.
on 15-06-2022 01:22 PM
Hi djrich
Thanks for your reply. If you do experience any further issues then please post back here to let us know.
on 15-06-2022 01:09 PM
Hi Debbie, it's been fine so far but last time there was about 10 days between dropouts.
on 15-06-2022 12:09 PM
Hi djrich
How has the connection been since your last post?
on 13-06-2022 01:10 PM
Hi djrich
That's great. Yes please can you monitor the connection over the next couple of days before sending the old router back.
on 13-06-2022 01:08 PM
Hi Debbie, new router arrived and setup, shall I wait to see if it's ok before sending original one back or shall I send back original router straight away?
on 09-06-2022 02:37 PM
Hi djrich
Thank you, please let us know how you get on.
on 09-06-2022 02:28 PM
Ok thank you.
on 09-06-2022 02:22 PM
Hi djrich
I can't see any issues detected.
I have ordered the replacement router, please allow 24-48hrs for this to arrive.
on 09-06-2022 01:12 PM
Hi Debbie,
If you think that would help then yes please.
Obviously you are unaware of any network outage in my area at that time then?
It lasted about 2 hours roughly.
on 09-06-2022 06:41 AM
Hi djrich
Would you like me to send a replacement router for testing?
on 08-06-2022 04:00 PM
Hi router is dropping connection again right as I type this.
on 06-06-2022 09:39 AM
Hi djrich
If you do experience any further issues then please let us know on this thread.
06-06-2022 09:38 AM - edited 06-06-2022 09:39 AM
Hi, it seems ok now, it's not dropped connection again yet.
on 06-06-2022 06:33 AM
Hi djrich
How are you getting on?
on 31-05-2022 11:54 AM
Ok, no problem. If the connection does continue to drop at the test socket then we can send a replacement router for testing purposes.
on 31-05-2022 11:47 AM
Hi just found out my old BT hub is locked to BT network so can't reconfigure it, will see how talktalk stability goes over next few days but I don't have a spare router to try.
on 31-05-2022 11:40 AM
Will do, thanks for confirming 🙂
on 31-05-2022 11:35 AM
Ok that's fine thanks.
