Connection dropping regularly
Message 15 of 15
My connection is dropping regularly - sometimes a few times an hour - very inconvenient when on calls when working from home etc.
This is the connection to the DSL - the Wifi etc is fine. The hub is connected to the test socket.
I have also unplugged the router for 30 mins and left it off overnight and it hasnt improved.
I have a new Huawei Hub so this suggests a possible line fault.
Please can someone get back to me on this.
14 REPLIES 14
Message 1 of 15
Hi highbalance
I have arranged the engineer visit for 09/09 AM (8am -1pm)
Message 2 of 15
yes i confirm potential engineer charges ok
AM would be best please.
Message 3 of 15
Hi highbalance
Thanks for confirming your details.
Please can you also confirm potential engineer charges and provide your availability for this visit AM and PM?
Message 4 of 15
Hi highbalance
Message 5 of 15
Yes i think that would be the best idea. Please can you arrange this for me?
Thanks for your help with this.
Message 6 of 15
Hi highbalance
This is the latest version of firmware for this router.
If the connection is dropping with 2 different routers, cables and filters at the test socket then the next step will be to arrange an Openreach engineer visit.
Message 7 of 15
Yes connection was dropping
Firmware: SG4K100130
Message 8 of 15
Hi highbalance
Was the connection dropping with the Sagemcom router? What firmware version was showing on the router?
Message 9 of 15
New router installed but connection now much much worse. Last night and today so far its nearly unusable due to uptime of minutes only in some cases.
Had to go back to Huawei router.
Please advise
Message 10 of 15
Hi highbalance
The Sagemcom hub is on its way and a returns bag for  your current router.
Please allow 24-48hrs for this to arrive. Let us know how the connection compares with this router.
Message 11 of 15
Yes I will try a new router first. Can you send a sagemcom router this time if possible? I have a Huawei router currently.
Message 12 of 15
Hi highbalance
Sorry for the delay.
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
Would you like me to send a replacement router for testing to see how the connection compares?
Message 13 of 15
No noticeable noise on line
Service centre comes back with no fault
Skynet_TX
Message 14 of 15
Hi @Anonymous,
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If you have a landline phone can you check to see if that is working normally (i.e. you have a clear dial tone and no noise on the line).
Most staff on this community won't be around until Tuesday now (there may be limited staff around on Monday), so you may get faster support by using the live chat or calling customer services on 0345 172 0088 over the weekend, however the staff here should respond to this topic early next week to help if you are still having issues.
