Connection gets slower and slower on WiFi until I restart the router
chrisrobbo
Message 3 of 3
Hi, I am fairly certain there is a fault with my router.
When my laptop is connected to the router via WiFi the connection drops down to 5-10Mbps after a short period of time. I can resolve this by unplugging the router and restarting it and then I achieve the normal 60Mbps using the same laptop in the same location over the same Wifi connection. However, within 30 minutes the connection speed grinds down to the really slow speed of 5-10Mpbs and sometimes <5Mbps.
I've tested another laptop in the same room and it experiences the same issues. But on a wired connection there is no drop off at all.
So I can only presume this is a Wifi issue with the router and it need replacing? Any ideas?
Message 1 of 3
Hi chrisrobbo
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router.
Skynet_TX
Message 2 of 3
Hi @chrisrobbo,
What make of router do you have ?
If you are only having issues with wireless devices then it is possible you are suffering from Wi-Fi interference (i.e. a neighbour having a router broadcasting on the same, or similar, channel to yours).
You could try changing the channels that your router broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
