Connection issues
Limpingadam
Chat Champion
Message 79 of 79
Speed overall on the router states it's gone up by 1.5mb but upload has halfed. from 600kb to 300kb
Started on Friday, now the response time is high on pages.
78 REPLIES 78
Message 1 of 79
Hi Limpingadam
Thanks for your reply. Please let us know how you get on once the engineer has completed the work on the line.
Message 2 of 79
Connection still the same but its because the guys found out the lines knackered, a new one as been ordered, he reckons it will get sorted within a few working days so result either way.
Message 3 of 79
Hi Limpingadam
This fault has been passed to BT Openreach so a line engineer can complete investigations. We should receive further updates within the next 48hrs.
Message 4 of 79
Hi Limpingadam
I've passed this over to our Network Team for investigation and I will post back on this thread as soon as I receive further information.
Message 5 of 79
We don't use the phone line and as they are separate parts of the line I'm not bothered.
There's no fault on the socket or the external line to the post (this happens every few months when BT start messing with the line)
Inspect the whole of this post, it's happened half a dozen times now.
Message 6 of 79
Hi Limpingadam
If you are experiencing a fault with the landline service then this will need to be investigated first as it can affect the BB connection.
If we raise a BB fault and there is a voice fault then this will need a separate engineer visit.
Message 7 of 79
No because we don't have one to hand, and none of our immediate neighbours use land lines, it's 2019.
The re-occurring issue will be the same issue from the past to do with the line interference in the underground lines. Log the fault with BT please.
Message 8 of 79
Hi Limpingadam,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which has detected a potential voice fault. Would it be possible to borrow a phone for testing purposes to rule out any issues with the voice service such as no dial tone or any noise on the line?
Message 9 of 79
Back again, been about a week or so, but got to the point where the streaming of video and such has become dotty and stalling loads.
Connection is down to 7mb and 400kb up.
In Gobowen, new cabinets have gone up all over the place, but it appears are connections suffered. Also noted someones got a cabinet a mile down the road (probably private they are loaded) but the connections been effected.
Message 10 of 79
Do you have a telephone you can test with or are you able to borrow one? It's just that noise on the line can affect your broadband so we need to investigate this first.
Message 11 of 79
Same functionality still applies.
We go around and around with this.
It's a BT fault with the line, usually in the past it's been the underground part but atm I believe it's the overhead wires in some places.
BT were down the week you asked me to leave the router off for half an hour so probably address' the line.
I guess this week all neighbours will start complaining about a slow profile.
I appreciate the replies but it's not a problem on my end.
Router is functional on both the one you hand us and my billion router.
As far as Im aware there is no crackle but I don't use the phone.
Message 12 of 79
Hi Limpingadam,
Sorry to hear you're experiencing problems again
Is your router currently connected to your test socket?
Is your telephone line clear (no noise)?
Message 13 of 79
Oh look its happening again.
There is a tree rubbing the line somewhere along the road.
Because again I'm down to 6 meg. Was 7 meg yesterday and 8 meg two weeks ago.
We had two windy nights over the weekend.
Again this is getting ridiculous.
Message 14 of 79
Thanks for the update, please let us know if you experience any further problems
Message 15 of 79
Appears to be sorted atm, though I've seen a BT van here for the last 2 days.
Message 16 of 79
Hi Limpingadam,
How are you getting on, have you tried switching the router off for 30 minutes?
Message 17 of 79
Hi Limpingadam,
Can you switch your router off for 30 minutes then switch back on and retest
Message 18 of 79
Nope. Could you advise.
Message 19 of 79
Hi Limpingadam,
Are you still currently in contact with the Complaints Manager?
Message 20 of 79
That said, theres still something not right here.
Getting stalling problems and the speed isn't what it's connected at when downloading, only ever can max about 5mb down instead of the full whack of 10mb.
Somethings not quite right.
