on 04-03-2021 05:00 PM
My wifi hub has been great, never really had much of a problem until last night. Got cut off around midnight for ages. Turned the router off till i awake around 5am. Since 5am my connection speed is less than 1mbps when i normally get 46mbps. Nothing has changed on my computer that is running windows 10 and connected wirelessly. I've tried connecting via cable too and that brings the speed up to 5mbps. Could you look into this please?
on 24-03-2021 08:18 AM
I'm sorry for the delay and thanks for confirming. Please let us know if the speeds do start to vary again.
on 23-03-2021 12:02 PM
Things are better now i'm back using my Wifi Hub. The spare router is useless at maintaining speeds. thanks
on 21-03-2021 10:26 PM
on 20-03-2021 04:15 PM
Yes everything seems back to normal although at times it seems to go a little slow but nothing of concern right now.
on 19-03-2021 10:52 PM
Hmm it would appear to have dropped again from around 8pm. Only getting 11mbps. While it's not back to square one, it's not at it's best either. I'll repost on Monday and let you know how it goes...
on 19-03-2021 07:53 AM
I'm really glad to hear this and thanks for confirming 🙂
on 19-03-2021 07:33 AM
on 19-03-2021 07:24 AM
How has your connection been? Have the speeds remained consistent?
Thanks 🙂
on 16-03-2021 07:24 AM
I'm really glad to hear this. I'll check back in with you on Friday to see if the speeds are still remaining consistent.
on 15-03-2021 06:15 PM
As of 6pm it's coming in at 36mbps which is a massive improvement for this time of day. I'll keep checking through tonight too and hopefully it will stay like this.
on 15-03-2021 12:50 PM
Thank you 🙂 No reset should be needed, please let us know how you get on 🙂
on 15-03-2021 11:06 AM
on 15-03-2021 10:38 AM
They have just confirmed that this should now be resolved. Please let us know how your speeds now compare later on this afternoon/evening.
Thanks 🙂
on 15-03-2021 10:24 AM
Hi jimmymumu,
One of our Network Engineers have taken a look and have identified a potential issue. They are just in the process of rolling out a fix and I'll post back to confirm once this should be resolved so you can retest.
on 15-03-2021 09:33 AM
Hi jimmymumu,
No problem, I'm hoping to hear back soon.
on 15-03-2021 09:10 AM
on 15-03-2021 08:23 AM
Morning everyone,
I'm sorry for the delay. I've escalated this straight over to one of our Network Engineers now and I will post back here as soon as they come back to be with an update.
on 12-03-2021 03:16 AM
I am also having the same problem that started with an outage on Thursday the 4th. Needs looking into as a bigger problem.
on 11-03-2021 10:29 PM
on 11-03-2021 06:06 PM
Just to add.
I'm also am located in the S35 area of Sheffield and have the same symptoms since Thursday the 4th of March. I usually get around 70mb/s, which I can get in a morning but this then drops in the afternoon to about 1-3mb/s, it stays like this till before midnight and recovers. This has been happening every day since that Thursday.
I have an engineer booked out for Friday next week. I'm adding this to Jimmymumu's post to point out this isn't an individual problem, and needs looking into on a local scale.
