Connection to wifi
Kayyy
Message 6 of 6
My devices all work  but when my talktalk router is on, the devices like the laptop does not connect. The laptop says connected, no internet.
5 REPLIES 5
Message 1 of 6
Hi Kayyy
Sorry for the delay.
Have you cancelled your service or would you still like help with this?
Message 2 of 6
On your laptop, please open a command prompt window (assuming a Windows OS) by going to:-
Start > Accessories > Command Prompt
In Windows 10, click the Window Icon & type:-
cmd
in the search box next to it. This should find the "Command Prompt" from there.
Once there, issue this command in the command prompt window:-
ipconfig /all
Then copy the command window output & paste it here.
To copy text from the command prompt, please see this site:-
http://www.howtogeek.com/howto/windows-vista/copy-to-the-clipboard-from-the-windows-command-prompt/
Things are even easier in Windows 10, just highlight the text & press CTRL-C and paste it into Notepad (to try & preserve the formatting) & attach the file at the bottom of your post.
Kayyy
Message 3 of 6
I phoned Talktalk a few times and they ran checks. I waited. It still does not work. So I decided to change providers.
Chris-TalkTalk
Message 4 of 6
Hi Kayyy,
Is your router currently switched on and connected to your telephone socket?
Skynet_TX
Message 5 of 6
Hi @Kayyy,
What light(s) do you have showing on the router ?
