on 06-06-2021 07:51 PM
Constant buffering when trying to watch tv, films will not work just shows a loading sign but 10 minutes later still the same. Tv is showing full connection to WiFi.
on 07-06-2021 09:33 AM
Hi Dean,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 06-06-2021 07:53 PM
Hi @Deanchristy23,
If you go to the Service Centre what does it show for your estimated speed range. If you log into your router to check your sync speed does this show speeds below that estimated range. If you run a speed test (ideally from both a wired and wireless device so that you can compare), how close are the speed test results to the sync speed shown on your router.
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
