Connectivity
Markram
Message 3 of 3
Why is my stream constantly buffering, we only live in a small bungalow, the router is in the hallway approx 4mtrs away from my TV.
Mr
Message 1 of 3
Hi Markram
I've completed a line test which hasn't detected any faults and your line is in sync at 62.6mb.
What speed are you receiving when running a speed test?
Skynet_TX
Message 2 of 3
Hi @Markram,
If you go to the Service Centre what does it show for your estimated speed range. If you log into your router to check your sync speed does this show speeds within that range.
Then if you run a speed test (ideally on a wired and a wireless device so you can compare the two), what sort of speeds do you get.
Then they will hopefully be able to respond to this post within a working day or two.
